I tried to use the Diagnostic Tool today on my 01 S (DME 7.2).
It read the fault codes and cleared them, the vehicle identification was correct but the Actual Values displayed were either blanks or illogical (e.g.temperature readings of -minus).
Do you have any opinions/experience on the matter? Is the tool supposed to perform all functions with all models/years, or is the Durametric Tool limited to fault code reading/deleting at present on certain cars?
i found this when I was looking at their site yesterday (I was trying to figure out if it could open the psm valves for bleeding, had to email them, it can't yet)
1997-2004 Porshe Boxster(986)
Module 	Read Codes 	Reset Codes 	Actual Values 	ECU Information
DME (Engine) 	Yes 	Yes 	Yes 	Yes
Tiptronic 	Yes 	Yes 	No 	No
Airbag 	Yes 	Yes 	Yes 	No
ABS 5.3 	Yes 	Yes 	Yes 	No
ABS 5.7 	Yes 	Yes 	Yes 	No
Alarm System 	Yes 	No 	No 	No
Air Conditioning 	Yes 	Yes 	No 	No
Seat Memory 	Yes 	Yes 	No 	No
If the engine was not running then that would be normal for some readings. You will get the same readings (under the same conditions) with a PST2.
Here is a screenshot of my car with just the ignition switch on - cold engine overnight.
You can also look in your log file and should see a list of readings taken.
Also, make sure you have the latest version 2.1 just came out a few days ago. You can always download the latest version at their site.
post-2-1146165244_thumb.jpgYou can also look in your log file and should see a list of readings taken.
By coincidence, in the meantime we received a support e-mail from Durametric saying among other things:
"We recently became aware that Actual Values on some versions of Motronic 7.2 are not working correctly. We are working on fixing this problem and will hopefully have it resolved within a few weeks at most. We apologize for any inconvenience this has caused."
So this seems to be our problem.
But even on your read-out Loren the exhaust temp. is incorrect (-54 F)
