I'm changing out my rear console, and want to take the oddments lid off my old console and put it on my new console.....Is it just a case of unscrewing things, or is it the same procedure (using rivets etc) as in the TSB for replacing the hinge on a 996 oddments lid....I have a 997 S
Many Thanks
The 997 console is quite different than the 986/996 console. The parts diagram looks like it has a similar hinge, spring and screws. It should be able to be transferred easily - once the console is removed from the car.
Thanks for the info Loren
