I have a '01 996 with wood door handle/storage bin trim. During driving, there is an intermittent buzzing sound from the passenger door panel (and less so from the driver's side) that I can stop if I push down on the portion of wood trim just above the metallic door opener. There is a couple of millimeters of separation (delamination) of the wood from the attached plastic mounting, and I think that the separation is allowing that corner of wood trim to vibrate. I've glued the trim down a bit, but there's still some buzzing sound. Any ideas on fixing this problem would be greatly appreciated. Thanks.
