Can somebody please tell me what the torque specs are for the two 8mm drain bolts and for the oil filter cover on a 2005 cayenne turbo? I need to know this before I attempt the oil change. I have a propensity to overtighten and always use a torque wrench with the correct specs to avoid this. Both engine covers have been removed. Thanks. :help:
Two drain plugs - 37 ft/lbs. (50 Nm)
Oil filter canister - 19 ft/lbs. (25 Nm)
Loren:
Thank you very much!
Are the two drain plugs on an 05 cayenne turbo both on the pan or is one on the pan and the other above the oil cooler?
Thanks. :D
