I have the Porsche 18inch Split rims, and am hoping to get them refurbished soon by shot blasting and repainting.
I just wanted to check that it is ok to split the split rims to carry this out and if I should note anything.
Many thanks
Before disassembly mark each half as to put them together exactly as they were originally. On some wheels they are machined accurately or trued after assembly to make them round and easily balanced. If you mix up pieces or bolt up original halves 180 degrees or so apart you could end up with an eccentric wheel. Mfg processes differ between makes. I learned this at the "School of Hard Knocks".
