Is the sports exhaust system, the wiring harness and switch still available for a 2004 (LHD) Boxster S?
If so what are:
1. The Part Numbers?
2. The cost of the parts?
3. The cost of fitting?
Edited by Nick_USA
The TSB has the part number for the kit. The switch is not included.
Thanks and I see the TSB, do you know how much an OPC is likely to charge for the work?
I saw in a previous discusion there are two type of switch, the TSB mentions one, but can you confirm the part number for the LHD switch?
