Hi, I just bought my first Porsche last fall and I have a concern. It is a 2000 Boxster 2.7L 5 speed. I would like to know what the normal position or range for the tempature gauge is, because mine is in the middle of 180 and 225. The coolant level is good, I cleaned the radiators this winter and the mixture is correct as well. Is this normal any input would be great. Thanks
In normal driving in my 98 Boxster, the needle is usually in the middle of the 8 in 180. In hard driving on a really hot day, it will be in the middle of the 0 in 180. The only time I've seen it go higher than that is during track driving on a 98 degree day - then it was about halfway between the 180 and 225.
So, if you're seeing the needle at that level during normal driving, it may be a little high.
Thanks, that answers my question. Do you have any ideas of what it could be? Like I said before I have cleaned the radiators and the coolant mixture is correct and full. Both fans are running(low and high speeds) thermostat is functioning as well, never lost any coolant. I have noticed that the water pump is new(previous installed). The boxster has 61,xxx miles and is a 2.7L manual trans. Any additional ideas would be great !! Thanks again
I have purchased a air-vac tool to pull a vacuum on the cooling system this weekend. I pulled vacuum(20in of vac.) on the system and it held indicating no leaks, filled system and test drove. It seem to drop temp. a little(3 degs. cent. on the scan tool, still around 99 degs. cent.)Any more advise would be great. Thanks Again!!!! :clapping:
