Need some help understanding what may be causing a PST2 to be unable to communicate with may '00 C2's ECU. I am getting the following error:
Negative Response: Unknown Negative
Response: 0x3B
Essentially, the PST2 can connect but is unable to see any of the available modules that should be coming up. It's almost as if the ECU is in a "lock out" mode.
Anyone with more PST2 experience than I able to help explain what may be causing this? Or suggestions on how to fix?
The PST2 work fine, I get similar results using Durametric software.
Any input welcomed.
Best.
DBudd
Can't get into any of the modules, via Durametric or PST2. All are ghosted-out. The error the PST2 throws is essentially the same (albeit different exception code) as what Durametric throws: unable to access any modules.
I can only get basic ECU information...VIN, running hours, number of starts, etc. So I can see this detail, but cannot get to the different modules.
DBudd
  • 2 years later...
DBudd
I have the exact same problem on my 99 996 cab trying to connect with Durametric.
I can only see the ECU info.
Can't see any of the module. "Module Failed to Initialize"
Any idea what might be causing this?
Fred
DBudd
Fred
You need to send a support request to Durametric - http://www.durametric.com/support.aspx
