Can someone please let me know the pin code on the pre 2001 ECU?
I can't find it in any of my manuals and need it for a data logger - this is for a cup car but until 2001 the ecus were the same
THX
JM
Is this what you need?
Close but no cigar yet. It's the diagram that shows every pin that goes in the DME e.g. pin 80 = rpm signal pin 81 = ... etc
My manuals (pdf versions...) has everything except that! I have the 964 and 993 manuals and they have a very simple page with a view of the connector and next to each pin the function...
TIA
JM
This, but for the 2001 GT3, is what I'm looking for (and it may be that it's very similar for the Gt3 to what is here below...)
This for a 1999 C2. You didn't mention what year car you have.
1 - Heating of HO2S after TWC
2 - Idle air control valve, closing coil
3 - Fuel injector, cylinder 1
4 - Fuel injector, cylinder 2
5 - Fuel injector, cylinder 3
6 - Ground point 9
7 - EVAP canister shutoff valve
8 - Check Engine MIL
9 - not assigned
10 - not assigned
11 - not assigned
12 - Crash signal (airbag)
13 - knock sensor 1 (cyl. 1-3)
14 - Medium pressure switch (A/C)
15 - Intake air temperature sensor
16 - Engine compartment temperature sensor
17 - Signal, mass air flow sensor
18 - Signal, H02S 2 ahead of TWC
19 - Signal, HO2S 1 ahead of TWC
20 - Ground, speed sender
21 - Signal, camshaft position sensor 1 + 2
22 - Ignition coil, cyl. 4 terminal 1
23 - Ignition coil, cyl. 3 terminal 1
24 - Ignition coil, cyl. 5 terminal 1
25 - Camshaft adjustment, bank 2
26 - Terminal 30
27 - Triggering of DME relay, terminal 85
28 - Ground, electronic system (shield)
29 - Idle air control valve opening coil
30 - Heating of HO2S ahead of TWC
31 - Fuel injector, cylinder 6
32 - Fuel injector, cylinder 4
33 - Fuel injector, cylinder 5
34 - Ground, sender
35 - Coolant fan, stage 1
36 - Coolant fan, stage 2
37 - Triggering of relay (terminal 85), secondary air pump
38 - Version coding (ground for Tiptronic)
39 - Fuel reserve pilot light
40 - not assigned
41 - Knock sensor 2 (cyl. 4-6)
42 - Automatic I/M test
43 - not assigned
44 - Signal, throttle position sensor
45 - Ground, mass air flow sensor
46 - Ground, oxygen sensors
47 - 5-volt supply for mass air flow sensor
48 - Nominal engine torque to TC control module
49 - Ignition coil, cyl. 1 terminal 1
50 - Ignition coil, cyl. 6 terminal 1
51 - Ignition coil, cyl. 2 terminal 1
52 - Camshaft adjustment, bank 1
53 - 5-volt supply, throttle position sensor
54 - Voltage supply for various components
55 - Ground, ignition
56 - Terminal 15
57 - not assigned
58 - Actual engine torque from TC control module
59 - Tuning flap (intake manifold switchover)
60 - Programming voltage
61 - EVAP canister purge valve
62 - A/C compressor On
63 - Triggering of fuel pump relay (terminal 85)
64 - not assigned
65 - Relay of engine compartment purge fan (terminal 85)
66 - Start-inhibit relay (terminal 85)
67 - not assigned
68 - Position switch/clutch switch
69 - A/C compressor requirement
70 - not assigned
71 - Ground, knock sensors
72 - Tank pressure sensor
73 - Oil temperature sensor
74 - Engine coolant temperature sensor
75 - not assigned
76 - Signal, H025 2 after TWC
77 - Signal, H025 1 after TWC
78 - Signal, rpm crankshaft position sensor
79 - Speed signal from ABS control module
80 - Speed signal output
81 - not assigned
82 - Coolant level
83 - Fuel gauge
84 - not assigned
85 - CAN low
86 - CAN high
87 - L wire
88 - K wire
I sent you a PM with some info...
Loren,
Something funny happened with my race car and I don't know what it is... The RPM should have been a white wire and the throttle position a yellow and black.
I could never find the yellow and black but I did find the white and guess what... NOTHING was logging.
I finally got the RPM signal from the violet/green wire in the OBD II plug, conveniently located in the middle of the rear section.
Thanks for everything!
JM
OBD II plug under the dash board?
Loren,
JM
Loren,
JM
No, it's a cup car so the OBD II plug is in the middle, behind the only seat.
JM
Loren,
JM
That's because the white wire is a input to the ECU which the ECU translates to an RPM signal and outputs via the wire marked "TN-SIGNAL" (Violet/Green I believe).
Should this also work on street GT3s, and more broadly 996s?
Do any of you know which OBD II plug pin the violet/green wire goes to? (I'm also debating tapping in through the connector versus splicing into the wire)
Specifically this thread was about an RoW (not US) pre 2001 GT3. And, Carerra's have had 3 different DME's so each should be reviewed independently.
Ah, thanks Loren, the variety must explain the lack of specifc information on various boards. So does that mean that the RPM signal is on different pins on the ODBII connector (not DME) for different 996 models? I would have thought that they might have kept that consistent. Is the best thing to just look for the violet/green wire (or could it be different colors?)?
I did not say that. What I am saying is that the DME's from MY99 are very different from the DME's used MY01. As well in MY05 they changed again. Some of the OBD II wiring is different.
The best solution is to say what year and model car you are interested in so someone can check the schematic.
Gotcha! For me, it's a USA 2004 GT3... thanks in advance!
For a MY04 GT3 (US) it will be A9 on the OBD II connector - should be a violet/green wire. So in this case it is the same.
Thank you very much!
Loren, any idea on a 12 volt rpm signal? Violet/Green is a 5 volt signal which does not work with Traqmate :-( This is for a 2003 996 C2 Thanks
A coil or fuel injector pulse would work fine
Got it working, just needed a seperate ground. It is a 12 volt signal. Any idea on what wire color is the 5 volt potentiometer sensor for the E-gas?
MY03 Carrera
Does anyone know what's the pin #/wire for the tach signal at the DME for a MY04 GT3?
Just as I quoted above - it is easiest to take it off the OBD II connector.
If you must take off the DME it is pin D17 (same violet/green wire.
Thanks Loren.
