Is it any coupling between dump valve and ABS system, for example if I change the dump valve to a not Porsche original, can I have a mismatch with the ABS and PSM system ?
I know that the PSM + ABS light came on when the hose from one of the Turbos came loose, Im not sure why but it must be a connection between how the engine goes and the ABS falure warning
