I noticed that there's a broken sensor on my drivers side lower control arm (2001 C4). It looks like it senses the vertical movement of the control arm, but I can't find it anywhere in the manual. Can someone help me out with what this is so I can get a replacement?
Shawn
If it is square looking then it sounds like the Litronics sensor (for when you are going uphill to adjust your headlights down). The ABS/PSM sensors are round and on the wheel hub carrier.
Thanks, Loren. You were right on. I would have never guessed I need to be looking at the headlight sensors...
