I would like to instal an antenna for my hand held Garmin. Looking for a stock look, reduce clutter of cables, etc.
Is it possible to utilize the antenna for the PCM II ? Can it be order separately from the PCM II (which I don't have). Does anyone know the part number? BTW I have an 03 986 S.
Bryan
I do not know if they changed the GPS antenna for PCM II. The part number for the antenna used on PCM I and Traffic Pro is 996 647 107 01, about $90. Your local parts department can tell you if the antenna changed for 2003. My parts list only goes to 2002.
Have no idea if it will work with Garmin, but it would be neat if it did. You could ask Horst on the Becker board but I doubt if he would know as Garmin is not a Becker product.
Let us know if you find the answer. Jeff
Nice instal. What year is your S? I need to double check the size of the sun sensor to see if it will fit my 03.
Bryan
Guest Brian Denuyl
Mine is an 02.
