I am ordering the ROW M030 suspension and wanted to know if it came with the rear bumpstops. I know that the fronts are re-used from the original.
Also, would it be a good idea to replace all bump stops when I install. My current suspension has 47K on it.
Thanks so much.
Adam
Yes, the 030 kit comes with new shorter rear bump stops. You can certainly replace the front ones with new pieces, but unless you have been bottoming out your suspension, or driving in some sort of corrosive environment, the fronts are probably just fine.
Thanks so much.
Adam
I just changed mine ... both front and rear bumstops are included.
Only the rear bump stop, no front. Here is a list of items for my 6speed 2002 Carrera 4 Cab
ROW M030 MY02-05 C4, Cab, 6 Speed
Porsche Part Number: 000.044.500.30
2 x 996.333.792.25, Stabilizer Bar Bushing (Front)
2 x 996.333.792.12, Stabilizer Bar Bushing (Rear)
1 x 996.333.701.26, Stabilizer Bar (Front)
1 x 996.343.703.04, Stabilizer Bar (Rear)
2 x 996.343.533.25, Front Coil Spring
2 x 996.333.521.27, Rear Coil Spring
2 x 996.343.043.23, Front Strut
2 x 996.333.051.34, Rear Strut
2 x 996.333.105.03, Rear Bump Stop (Yellow)
Only the rears are included in the retrofit kit. The fronts are the same as stock.
