Recently my '99 Boster (67k miles) began having intermittent starting problems. When the clutch pedal is depressed and the key is turned nothing happens. Depress the clutch again and it turns over fine... I replaced the ignition switch two months ago with no problems since. I've read posts about bypassing the clutch pedal switch, how is this done? Has anyone replaced this switch recently? Any other ideas? Thanks.
