well, my valve cover gaskets are leaking a bit and i'm going to replace them myself. as i understand it, all of the cam bearing caps are integrated into the valve cover except one. porsche makes a tool that is installed onto the cam ends prior to removal of the valve covers. my question is: do i need this? are the bearing caps at the gear ends of the cams sufficient to hold them in place when the valve cover is removed? if i do indeed need the tool, does anyone know where it's available (or what the dimensions are so i can make one)?
second question: while i have the valve covers removed, is there any other maintenance i should take care of? spark plug tubes are a given. anything else? (99 box, btw)
