so I drove a lot since november and just turned 14k miles, I figure I'll hit 15k in a month but some time before then my regular warrantee runs out and the CPO kicks in
I know the majority of the service I can handle, my question is this, is it worth bringing the car in for them to do the inspection and get the RMS replaced if the see fit? I understand the cost to be $350-500 so the parts would be a good bit less ($150ish I figure)
here's the rms
http://www.renntech.org/forums/index.php?&...gallery&id=1185
it doesn't drip in the garage, nor has my oil level dropped noticably over the 5k miles (not even a bar on the digital display)
any advice?
thanks,
Tom
Edited by stumpjumper
Have them fix the RMS under warranty and have the car fully inspected. Have coolant and other fluids checked.
Pay for an oil filter change and oil itself should be free while RMS is done. 2 birds with one stone.
wow that was stupid of me, I somehow forgot that the oil needs to come out to do the RMS :P
From the looks of this photo, you may not have a weeping RMS. That brown/black stuff on the bellhousing is cosmoline that has picked up road grime. It does not look like there is any shinny oil that would indicate a leak.
But no harm in letting your warranty dealer confirm that. You don't have to bribe your dealer with letting them do your oil change to get warranty service, just go down and ask them to look at it. A technician can tell very quickly by looking at the gunk on the bellhousing if it is oil from the RMS/IMS or just road grime.
Ditto on what Orient Express said. If it is RMS, definitely make sure the oil filter is changed (which isn't done unless asked). You'll need to change the cabin filter as well (5 min close to the battery under front trunk).
You said you are losing oil but the oil level hasn't dropped. Check oil level when engine is cold with the dip stick when car is flat. The pic doesn't seem like RMS to me either.
yup, it's lost what I'm guessing as 1/2 a digital bar, sometimes it shows 1 down, sometimes it shows full, on the stick it's just a smidge lower than when i got it so I don't think it's dropped 1/2 a quart and I figured that since the car was used so little before I bought it that this would be normal for a little while
guess I'll take it in just to be safe, that's a fair gamble :)
One bar is NOT a quart....
The bars are about 1/5th of a quart ... consider that the 2 marks off to the left of the bars indicate max and min and the difference is 1.25 litres per my owner's manual page 76 and there are about 6 bars between those 2 marks. Since 1.25 litres = 1.32 quarts and dividing by 6 you get .22 quarts per bar.
And, you should be down 1 bar from the top as the max line is between the top and second bar so there is no harm if the top bar in unlit.
A fluctuation between on and off is probably attributable to the difference in the time you have allowed the oil to settle and how warm the engine oil was when you took the readings.
