So here's a strange one for y'all.
Friend was over last night. He has a boxter but he came in his wife's car.
Anyway, hew was admiring my car and when he looked into the engine bay the
first thing he said was where's the light. Search me I said? I have had the car
almost 4 years and I guess since its never had one I didn't know it's supposed to be there.
So my question is where is the light supposed to be in the rear engine bay?
Why would it be missing? Probably forgot to add it on the manufacturing line.
Pictures would be cool. Part numbers and wiring diag would be even better.
Cheers,
Berny
The light is attached to the outside of the circular fan frame on the engine compartment lid, at about the 5:00 position, sticking out to the right. Perhaps the bulb burned out--the clear bulb cover faces straight down, so it's easy to miss if the bulb doesn't light.
Thanks Poursha. I checked it and I see the connector but no light.
No wonder I never missed it tucked under that fan housing. Just a completely empty slot where the light should be.
Loren I need to order this. The wiring is there and I checked with a voltmeter andpower is there at the connector. Any ideas on part number?
Cheers,
Berny
The bulb is: 900 631 106 90
The socket assembly includes:
959 632 201 01 light
815 971 989 B plug socket
N 017 490 6 connectors (2 needed)
Chances are you just need the bulb and holder (what they call light)
Thanks Loren, i will get it ordered tommorow.....asuming they are working on Xmas eve ;)
Happy holidays and many thanx
Berny
