I'm getting ready to replace the cv joint boots, but I don't have a socket big enough for the axle nut. Could anyone please tell me what size it is. Thanks!
2000 986S 6sp, US model, 63,000mi
I was going to say the same thing as Loren, because the shop manual has it listed a 22 mm. But with the lousy Porsche shop manual that could be the diameter of the threaded shaft, and not the nut on the end of the shaft.
On my 1997 the nut is 32 mm.
It's most likely the shaft diameter. M22x1.5 means Metric 22mm diameter by 1.5mm pitch. The nut itself will be much bigger - 32mm sounds about right...
Shash
