can any one help me please???? #1: how do i replace the ignition in my 951? what do i have to do? the ignition won't lock, so i bought a new ignition w/ a key. and #2: my sunroof leaks, but i had all the drain holes blown out; it leaks in the back passanger corner. please someone help me out i have tired and tried!!! i need someone's help ASAP!!! thanks
the ignition, you need to remove the blind bolts and remove the assembly. you probably have to drop the steering column some.
the sunrrof check your drains. open the roof and pour water in the drains are behind the rear wheels and down the A pillar
