I left my house this afternoon, stoppped at the mail box, left the car idling for about 5 minutes, then drove about 1/2 mile when my car (1999 996 C4) started sputtering. Immediately, the check engine light started flashing and soon thereafter, stayed on full time. I immediately slowed down and lumbered back home, careful to keep the car at low speed, etc.
When I got home, I turned off the car, then restarted it, the check engine light was gone. I drove the car about an hour later .... no problems / back to normal.
I did change my plugs recently .... but havent had any issue up to this point.
Any thoughts / insight?
Double check that all cables are secured properly to the CORRECT coil packs for the plugs.
That is the one problem I know it is not ....
OK, I just had my car connected to the OBD-II. The codes are P0304 (misfire on cyl 4) and P0302 (Misfire on Cyl 2). Give that I just changed my plugs in the last 7 days, is it possible that 2 plugs went out of should I look elsewhere for the problem. Also, is there any possible correlation between #2 and #4? Thx!
Edited by skymast
It really might be worth it to re-install the coils and the connectors to the coils. Something may be loose and not making full contact.
Sounds like intermittantly faulty coil packs to me. Check the coils on those two cylinders for any hairline cracks.
OK... Luckily it was a 'amateur hour' problem. Unfortunately the OBD doesn't have this fault code!!! #2 was fine (not sure why I got a misfire read out) but I must not have connected it 'until it clicked' on #4. Thx for the insight. M
