Anyone has the gear rations for the 40th Anniversary?
specifically how many km/h per 1,000rpm for each gear ?
Last night I hit 263km/h with 6th gear, tach reading arnd 6,100rpm. Wondering what was the actual speed ...
Mathew
1^ 3.82:1
2^ 2.20:1
3^ 1.52:1
4^ 1.22:1
5^ 1.02:1
6^ 0.84:1
Reverse 3.55:1
final gear ratio 3.44
1^ 8Km/h for 1000rpm
2^ 16Km/h
3^ 23Km/h
4^ 29Km/h
5^ 35Km/h
6^ 42Km/h
rear tires are 285/30 18 (standard), that means I can you the figures you posted to determine actual speed (km/h per 1,000rpm) ?
Are you sure 1st gear gives only 8km/h per 1,000rpm ? That means at redline (7,300) still can not reach 60km/h...
I am sure 1st gear tops at around 65 km/h
Edited by mat911
Your first gear limit with those tires at 7300 is 40.89 mph or 65.81 kph. Third gear at 6000 rpm will give you a speed of 84.46 mph or 135.93 kph. At 4000 rpm in thirid, your speed is 56.31 mph or 90.62 kph.
OR:
At 7300 rpm, maximum speed is as follows (MPH):
1st - 40.89
2nd - 71
3rd - 107.76
4th - 128.03
5th - 153.14
6th - 185.95
and if you want to have some fun....reverse maximum speed would be - 44 mph.
Edited by 1999Porsche911
