Could someone tell me what the cylindrical thing is in the pic below? This is a 99 Boxster 2.5 base engine.
It's hard to tell what you're looking at in the next picture, but it is a close-up of the base of the cylinder. It has a small amount of oil leaking from around the tube that's connected there. The arrow then points to a...?
Thanks everyone! I'm learning...
  Loren said:
Looks like the oil separator.
It also seems that it might already have been replaced. The Oil Separator in your picture is the newer version with the vertical diaphragm. I don't think these originally came on a '99. Below is Doug D's picture of his new (left) and old (right) oil separators.
The part I'm looking at is more towards the front of the engine - and underneath the intake manifold. It's shaped like an oil filter with a slot cut into it.
