The one touch up or down function at passenger side window doesn't work. The window operates ok when you continuously press the button, but the one touch feature simple is not there....
Any suggestions ?
Carrera 40th Anniversary
When the window is at the top of its travel in the fully closed position, press the window switch again for a second or two. This will reset the 'pinch protection' on the window.
