Hi All,
i made a very small dent on the stainless steel trim plate right above the rear bumper cover, does any one know how to remove it so i can repair it? Are there any bolts or if the plate is just double side taped on?
Many thanks!
Willy
I think you just carefully pry it up to pop the clips loose. I think you may need to take the bumper cover off to do that though. The service manual shows it with the bumper cover off the car.
  • 4 years later...
I've resurrected this old thread hoping that somebody has found a nicer trim plate to replace this ugly satin-coat finished one with.
If not, I'm considering having it removed and painted however I have a feeling that the coating won't hold up all that well; given the heavy traffic. Carbon Fiber maybe?:help:
one option;
buff it to a nice shine !
I did mine and it looks really good now
David
Thanks David. I guess that would be an option that I have yet to explore. At least it would match the chrome exhaust tips!
Just the same, I'm surprised that Tequipment doesn't have a replacement panel in CF or anothr custom color.
The easiest way is to remove the cover then you can attack the clips from the underside. Its not to bad a job except for removing the rear light clusters which can be nerve wracking
