When I had my local dealer align my C4, they gave me a printout from their equipment indicating what all the specs were, and where my car was before and after the alignment, with respect to the specs and tolerance ranges. I'll bet your local dealer would be able to provide such information for you. It could also be found in a Cayman service manual, which I do not own...
Thanks. I'd like to have the alignment spec's in advance of going in for alignment, just to consider them and to consider my options.....
I checked in the manual; Porsche did not publish the alignment spec's!
Again, does anyone know a reliable on-line source for this info?
The Cayman service manual is currently only available using a dealers PIWIS tester. If you are lucky you can find a dealer with a PIWIS that has a printer attached and get them to print out that page. If you do please post the page here.
