I have a 2000 US Boxster with 2.7 tiptronic. When the engine gets hot, there is a noise like a bad alternator or pulley bearing at low rpm especially engine braking. Noise persists for a second after engine is turned off. Has anyone experienced this?
  • 3 years later...
Was there any answer to this?
Check the pulleys - the bearing do go bad and then they wobble. Sometimes when they break they take out the alternator too - so best address this asap.
