I am bringing in my 99 c2 for its 60K servicing and I want to have the mechanic do a FULL inspection as my CPO Warranty will run out this summer.
Any suggestions as what to look for? What are the most commom things to go wrong?
Jarrod
Did you read the Maintenance Checklist here?
Beyond that I would look for coolant tank leaks, RMS or any other engine oil leaks, tightness of the swaybar mounts, and if your brake fluid has not been changed in the last two years it should be.
