I have a 2003 Targa. I have read all the archives that the search routines will pull up. I want to exchange my black gauges for aluminum ones. I have found a set which includes a different cover. I'd like to exchange both items, I think.
Can the dealer reprogram the proper mileage from my car into the new gauge set? Any advance preparation required to accomplish that feat? Is there any concern for using a gauge set from an earlier model car just so long as it's a 996? Is the cover easy to remove from the dash once the gauges are out? Any tricks or perils I should know about?
I see several different messages about pulling the gauges, but I don't see anything that details how the cover and the gauges come completely off. Is it easy once the gauges are out?
Any direction will be very welcome.
Dwayne
Yes, it is a 10 minute job with a PST2. No advance prep needed.
Yes, the cluster design was updated in MY02. It is a fairly major change so you will need gauges out of a MY02 or newer car with a like transmission (Tip cluster is different also).
Yes, if you know the tricks. Do a search here for cluster and you will find several posts with pics.
