I stopped by the dealer yesterday to get an opinion on my tires. 27+K miles on the original Continentals. Fronts were OK, right rear worn a bit, left rear worn a lot more, especially in the middle. The service manager said the left side gets power before the right side, hence more wear, and if I got that many miles I shouldn't mess with alignment. I usually check tire inflation every month or so, and keep at Porsche specs from the owner's manual
I plan to get new rear tires in the near future. My questions are, is this true about power going to the left rear tire first, and is it OK to skip getting an alignment? The tire shop the dealer recommended doesn't have a Hunter machine for wheel balancing -- should I be worried?
