What is the part number for the male end seat belt buckle on a GT3? This is the part that slides on the belt.
As Loren indicated in the other thread, the male part that goes into the buckle is not available on its own. This is because it will not go through the ends after they have been sewn-in. You have to buy the complete seat belt which includes the bottom reel, the top and bottom hooks and the actual part you are talking about. Available in four colors for the GT3.
Thanks for the info. I called around and found a pair from PE Products in Los Osos, CA. www.peparts.com
PE Products sent the buckle connectors, but they were the wrong size so I will have to send them back. Looking at the car, I realized that the belts can easily be routed behind the GT3 bucket seats and into the buckles. This is clean, easy and cheaper, so that is what I'm going to do.
