Hi,just noticed that when sitting in my C2 996 1998 a noise coming from the ventilation unit in the centre consol, sounds like a hum or a whine/ fan and is on even when the ac and ventilation is off but the ignition on, it's still there when the enginee is turned on but obviously less noticable due to the engine noise, anyone any ideas how to get rid of it? thanks
Take the A/C control out of "Auto" by using the fan switch (minus button) to turn the completely off -- keep clicking the minus button until the display says "off". If the noise goes away then it is the Heating/Cooling fan.
I believe all cars circulate a small amount of air whenever the key or ignition is turned on even if the heater and venting is manually turned off.
