i have separate brake pads on the front that i swap out for track days. the rears are street pads that stay on at the track. my last track day, i cooked my track pads pretty bad. i'm still having problems with the street pads, though. i'll try to explain how it feels as best i can.
when the car is cold, the pedal requires a LOT of pressure to get the car to stop. its as if the front pads (Mintex Street, by the way) just won't grab. if i do a FIRM decel from 70 - 20, the car doesn't seem to slow down much at first. then, once they heat up, they stop the car like a champ. after 1 - 2 firm decels, everything seems fine. its as if the brakes just aren't working when they are cold (normal for race pads; not for street). also, they're not pulling to one side or the other; just not grabbing.
here's what i've done:
new pads all the way around (Mintex Red)
new rotors (rear)
hone rotors (front, cross-hatch)
flush / bleed with power bleeder, ATE fluid
pressure test (no leaks)
inspect master cylinder (no visible leaks)
verify caliper orientation (small piston leads)
verify caliper piston function
replacing front rotors today just for the heck of it, but i don't think it will make much difference. any ideas?
My thoughts
1. front rotors are really glazed over bad.
2. brake fluid is full of air - but should have been taken care of with bleed. Pedal should be rock hard.
let us know what happens with front rotor replacement.
The verdict is in: Rotor Glaze. Never experienced to this extent before. Installed new rotors, bedded the pads and they work like a champ. Thanks.
