Hi All,
I am looking at geting another boxster, and have seen one I like but it does not come with traction control, could anyone tell me if this can simply be added by adding the on dash switch??
Many thanks
Russ
further expansion: the boxster w/o traction control has 3-channel abs. for traction control, the car would at least require the ability to individually modulate braking between the two back wheels. traction control models have 4-channel abs.
since anything is possible, i suppose you COULD install a 4-channel abs modulator and program the ecu to manage it, but this is likely several thousand dollars and a huge pain to accomplish.
