Help!!!!
I took my 1999 Boxster into the dealer to have the "check engine light" problem repaired prior to a smog test. I have done 150,000 miles and so far had almost no trouble with the Boxster. The dealer came up with the following codes:
1. P1115
2. P1117
3. P1118
4. P1119
5. P0102
Any ideas on what the problem could be!!!!!!
Mel
P1115 Oxygen Sensor Heating 1 After Catalytic Converter - Above Upper Limit
P1117 Oxygen Sensor Heating 1 Behind Catalytic Converter – Below Lower Threshold
P1119 Oxygen Sensor Heating 2 Ahead of Catalytic Converter - Below Lower Limit
P0102 Mass Air Flow Sensor - Below Lower Limit
If you join Renntech as a contributing member you get access to the codes. Your P0102 code indicates a faulty Mass airflow sensor most likely but it could also be the connector or faulty wiring. This as I understand can also cause the P1115 error code. The codes p1115-9 could also be caused by a faulty O2 sensor(s). I will let Lauren or Tool Pants confirm. A good discussion of the mass air flow replacement instructions can be found at this link.
http://www.renntech.org/forums/index.php?s...3117entry3117
You will still need to get the CIL cleared at the dealer. Also in the future you can use the search function to search this web site for error code information.
  • 3 months later...
I have the same problem. I visually checked the MAF connection wires, cleaned the MAF, reset the code and the problem came back almost immediately. I replaced the MAF and the problem came back (after several hundred miles).
Which connection(s) were bad? The wires going into the MAF plug or the other end (wherever that is)?
