I just read the GT3 post about rotor thickness and that got me wondering the same for my 03 C4S. So, what are the specs?
TIA! :clapping:
For the C4S...
Brake disc thickness, new
front 34mm
rear 28 mm
Minimum brake disc thickness (after machining)
front 32.6 mm
rear 26.6 mm
Brake disc wear limit
front 32.0 mm
rear 26.0 mm
Peak-to-valley surface roughness of the brake disc after machining, max. - 0.006 mm
Thickness tolerance of the brake discs, max. - 0.02 mm
Lateral runout of the brake disc, max. - 0.03 mm
Lateral runout of the wheel hub, max. - 0.03 mm
Lateral runout of the brake disc when installed, max. - 0.06 mm
