Rotor skimming
GreigM
Can anyone tell me what the minimum allowed rotor thickness is? I currently measure 32.5mm - does anyone know how much skimming removes, and if I would have enough left afterwards?
For a GT3 mk1:
Brake disc thickness, new
front 34 mm
rear 28mm
Minimum brake disc thickness (after machining)
front 32.6 mm
rear 26.6 mm
Brake disc wear limit
front 32.0 mm
rear 26.0 mm
I think you are going to need new rotors...
