Car - MY99 996C4.
I've bought some Porsche wheels off e-bay which I intend to use on track with track tyres - the offsetsize etc is the same as my current set as follows :-
10Jx18 - ET65
7.5Jx18 - ET50
So no issues there that I can see, however, two things worry me - one they are 993.xxx part numbers and two, the front wheels are different part numbers as follows :-
Rears - 993.362.140.04 (both)
Fronts - 993.362.134.05 and the other is .06
One feels slightly heavier than the other and the spokes are different construction (is one a hollow spoke?)
Question is - would it be OK to use one of each on a single axle, would the weight different really count ? (Can't be more than 0.5Kg or so...).
I assume offset/size is all that matters with wheels, so 993.xxx wheels are fine (on a 996) ?
Any advice would be most welcome ...
Richard.
Rears are Turbo Look 18" wheels.
Fronts:
993.362.134.05 Techno Wheel 18"
993.362.134.06 Turbo Look 18"
Those two fronts should look slightly different if you look closely.
The fronts should be in pairs with the same part number.
Many Thanks Loren, as always fast and accurate info !
I'm going to study the fronts tomorrow, I swear they are identical !
Thanks again,
Richard.
