Is it possible to simply swap the Porsche Hi-Fi MOST bus amp with a BOSE MOST bus amp? Has anyone tried this? Does it over an improvement? Do wires have to be cut because of plug differences.
Many thanks,
Damian
Bose has 11 or 12 spkrs, dep on cab or coupe. I think the amp is different (more channels and power). I doubt you can swap. If you are trying to change your hifi to bose, i'd go aftermarket instead to save money and get best sound.
Thanks for the reply, I saw one on eBay and just posed the question. Basically if it worked and offered a minor improvement over my current Porsche Sound Package then it would be worth considering. I've already upgraded the speakers to MB Quart all round and didn't fancy replacing the MOST headunit and amp.
Damian
