How do I successfully remove this piece without scratching the leather dash or the finish on the piece?
Thanks in advance....
Edited by sentipede
Easiest way is with a plastic butter knife or pot scraper. Just insert it from the bottom and pull the panel towards you, it will pop right off, with no damage. B)
With the same trick work for the 2004 996 (radio/cd option, no navigation)? It looks like it's one piece (horseshoe shaped).
Slightly different... you need to release the clip in the center vent first. See the posts here.
Got it - thanks
Mike
