I've got a 99 Carrera C2 Coupe and i'm looking at buying a new set of alloys for it, fancied a set of 'Work Rezax II'
Any body know what size i can fit without rolling the arches.
If i did need to roll the arches how much work is involved ??
Porsche specs 17" and 18" wheels for the MY99 Carrera in matched sets.
The front fenders are rolled from the factory. Tires sizes spec will veery with wheel sizes.
17" Porsche spec wheels:
Front: 7 x 17 offset 50/55 mm
Rear: 9 x 17 offset 55 mm
18" Porsche spec wheels:
Front: 7.5 x 18 offset 50 mm
Rear: 10 x 18 offset 65 mm
or
Front: 8 x 18 offset 50/52 mm
or
Rear: 11 x 18 offset 63 mm
Only a couple of tire brands will fit the last option (11" rears) without rubbing.
On my 996 C2 I installed 18x10's 54mm offset with 285/30's will just barely clear the fender lip without rolling it. When I first got the wheels, I didn't think they were going to clear, especially with my H&R springs. I removed the strut on one side, bolted the wheel/tire back on, and lowered the jack to let the suspension swing up through it's arc. Turns out it clears by something like an 1/8 of an inch.
On my 99C4 i went up to a 19x8 in the front and a 19x9 in the back with no issues at all. I believe they are a 32mm offset if i'm not mistaken
Sorry I meant 19x10 on the back
or
or
Loren,
From this info you posted earlier, are these the rim sizes and offsets for all narrow body 996's. ie: C2, C2 Cab, Targa - MY '99 thru '04
Dwayne
Correct - for narrow body 996 series cars.
Cheers for advice,
decided on 18" to go with H+R springs i bought few months back, what does the offset mean is it the centre of the wheel compared to the outer rim also what is the ET measurement.
Cheers for advice,
Offset is explained very well here
Would the Mich Pilot Sports happen to be one of the tires that would fit without rubbing?
Also what tire size would be best for those wheels? (Front: 8 x 18 offset 50/52 mm Rear: 11 x 18 offset 63 mm)
-Shawn
'99 911 C2 6spd
The "Porsche approved tires for the 11" wheels are all 295/30 ZR 18.
Continental SportContact 2 N2
Pirelli PZero Asimmetrico N3
Bridgestone Potenza S-02A N3
Michelin Pilot Sport N1
I've looked throught the forums but still can't find where the wheel/tire size FAQ is posted? Sorry to be a pain. :S
I'm asking because it sure seems like there are more 19" wheels availible than there is 18" and I'd like to see what tires would work for my '99 C2 assuming a 19" wheel.
Edited by 911dark
Cheers for advice,
Curious on offset for the RUF wheels. since the front 8.5 is larger does the wheel use a wider or skinnyer tire and do you know what TPMS option is??
Front 18" x 8.5" 58mm varies for application TPMS option available
Rear 18" x 10" 66mm varies for application TPMS option available
