Being new to Boxsters, I would appreciate this Board's knowledge and experience. When driving my '97 Boxster in either 2nd or 4th gears at a constant speed, should I let up on the gas pedal, the gear shift lever moves very slightly forward. This movement is not present when in 3rd or 5th gears. What, if any, concerns does this suggest? Many thanks for taking the time and trouble to answer my query.
The shift lever will move a bit in either direction when you get on or let of the gas pedal. This is normal because the engine/transmission have rubber mounts.
