How do I remove the trim around PCM I ?
I ám going to install the PSE switch
/Magnus
PULL!
Work from one side (under lighter) with a plastic spatula, but go slowly. When you can grip the edge, pull gently outward from the dash, and work your way around the horseshoe piece pulling it out.
/Magnus
PULL!
It was easier then i thought
/Magnus
