996 Speedomter intermittent
Hey guys, new from the Roadfly message forum - not much discussion in there RE: Porsches. Anyway - my speedometer is acting intermittently - i've checked fuses - don't know about the relays. I am used to older porsches, so not sure if it is the speed sensor? a crimped wire? searched the past archives, most info on disabling PSE.
Thanks all - would like to have my speedo so i dont get any tickets!
99' 996
The digital portion or analog (needle) portion? or both?
Any mods that use the speedo signal like PSE or PCM? or ?
Neither portion works. No mods as far as i know - recently purchased the car. Got under there to see if anything was disconnected, but all i found was the reverse signal. =/
TIA
