I'm about to loosen the 4 control arm retaining bolts a the front of the diagonal control arm and I would like to know when I do so - will that inner assembly drop down on me?
I have to remove the 4 bolts to swap out the old with a new bar, but I'm concerned that without 'apparent' support, it will drop down.
Also, the Bentley book (pg 40-4) has a table that show torque settings. Am I reading it correctly to assume those bolts need 88 ft-lbs?
Will it require a new alignment as a result of loosening the diagonal control arm supports to swap out the bar?
thanks,
kj
