Help locating an undercarriage Boxster part
Hi Loren,
I have a #5 panel which I need to install. Can you give me part numbers for the fasteners: #2, 6, 7, 8, 13, 14?
p.s. Do you happen to know if there is a version of PET which runs on "small" monitors. The program I have doesn't like my laptop's 1280x800 widescreen display.
Hi Loren,
PET online at Sunset Imports
Item 5 - Cover, rear -- 986 504 119 00
Item 2 - Plastic nut (21 required) -- 999 049 022 40
Item 6 - Expansion rivet (as needed) -- 999 507 497 40
Item 7 - M6 hex nut -- 999 076 068 09
Item 8 - Stud M6 x 11 -- 999 919 169 02
Item 13 - Self tapping screw (as needed) -- 999 073 061 02
Item 14 - Spacer sleeve (as needed) -- 944 503 255 00
  • 4 years later...
Hi guys,
Great to chat with you again. It has been a very, very busy year....My first born just turned a year!
Well....to the point: the plastic underneath my Boxster is deteriorating a bit and I might need a bunch of the undercarriage plastic parts.
In addition to that, this weekend I went to get a code read at Pepboys in Parsipanny, NJ and the f*** guy who drove the car to the service area, accidentally drove over a lift arm and broke the plastic part that is attached underneath the front bumper :censored::soapbox:
Where do I get a complete diagram of the parts? I tried the link above and it didn't work.
Thank you so much.
All the best,
Gus
Hi guys,
Thank you so much.
All the best,
Gus
Is the part not in post 2 above? If not, then it is part of the front bumper assembly not the under carriage.
Thank you so much, guys!
I found the part number in the PET diagram posted by geoff...
You guys are the best.
FYI the parts I was looking for were:
996 505 525 00
01C
996 505 526 00
01C
All the best,
Gus
Edited by gandrade1
