I just received my fabspeed muffler bypass pipes. Does anyone have information on installing these? I have a base 997. I would appreciate any help as I was unable to find any DIY instructions. THANKS!!
Try looking under the PSE installation headings on this site .
There are step by step instructions with drawings .
(I assume you are looking for info. on how to remove/ re-install the mufflers?)
If you cannot find it , I am sure someone at the track will be happy to help you out .
Once the mufflers are out, you can use the factory sleeves and hangers to connect the Fabspeed pipes to the cat. outlets .
If you plan to do this on a regular basis , you may want to check with Fabspeed. They make st.stl. clamps which may make it a little faster to swap the components.
Have fun at the track.
Edited by Jean
