post-2-1139933291_thumb.jpgTop model in 911 range to debut at Geneva Motor Show
ATLANTA, Feb. 13, 2006 – Porsche today revealed the first official images and information on the new 2007 911 Turbo. The sixth generation of the range-topping 911 model features a revolutionary 480-hp, twin-turbocharged, 3.6-liter boxer engine with the world’s first gasoline-engine application of variable turbine geometry (VTG), a redesigned all-wheel-drive system, and evolutionary styling.
The new 911 Turbo’s engine produces 480 hp at 6,000 rpm, 60 hp more than its predecessor, raising specific output of the 3.6-liter boxer-Six to an all-time high of 133 hp per liter. More notable is the engine’s torque curve, which has been bolstered and broadened by the variable turbine geometry system. Peak torque rises to 457 lb-ft (previously 415 lb-ft), but that peak now spans an extended rpm range from 1,950 to 5,000 rpm, compared to 2,700--4,600 rpm in the previous 911 Turbo. Additionally, a function in the optional Sport Chrono Package allows a 10-second, mid-rpm-range ‘overboost’, temporarily increasing turbo boost under full throttle by 2.9 psi, and swelling peak torque to 502 lb-ft.
A 911 Turbo equipped with the optional 5-speed Tiptronic S automatic transmission requires only 3.4 seconds to sprint from 0 to 60 mph (0-100 km/h; 3.7 sec.). Equipped with the standard six-speed manual transmission, the new 911 Turbo reaches the same 60 mph mark in 3.7 seconds (0-100 km/h; 3.9 sec.). With either gearbox, the top track speed of the new 911 Turbo is 193 mph.
Much of the 911 Turbo’s improved performance can be attributed to the variable turbine geometry system, the first such system available on a turbocharged gasoline engine. The heart of the technology is adjustable guide blades, which can vary in angle to most effectively guide engine exhaust flow onto the turbocharger’s impeller wheel. The result is a system that provides the advantages of both a small and large turbocharger, improving flexibility and acceleration, particularly at low engine speeds.
To transfer this power to the road, the new 911 Turbo features a redesigned all-wheel-drive system, with an electronically controlled multi-disc clutch replacing the previous model’s viscous clutch. Porsche Traction Management (PTM) allows variable power distribution fore and aft, and depending on conditions, the system’s electronics constantly determine optimal torque distribution to ensure ideal traction. In use, PTM provides exceptional agility on winding roads, outstanding traction in inclement conditions, and impressive active safety even at higher speeds. Though powerful, the 911 Turbo’s PTM setup is one of the lightest all-wheel-drive systems on the market.
The new 911 Turbo’s accelerative performance is duly tempered by its brake system, which is comprised of six-piston monobloc calipers up front, and four-piston monobloc calipers at the rear. Brake disc diameter at all four corners has been increased 20mm, to 350mm (13.78 in.). Optional is Porsche’s Ceramic Composite Brake system (PCCB). In addition to the exotic pad and rotor material, the PCCB option provides an increased front disc diameter (380mm /14.96 in.), absolute corrosion resistance, improved fade stability, and a 37-pound unsprung-weight savings versus the standard brake system.
Styling changes made to the new 911 Turbo are evolutionary. The modified front end features tautly drawn cooling air inlets, widely spaced and deep-set fog lights, and new LED indicators situated in the lateral air inlets. From the rear, the Turbo takes on a more powerful stance thanks to a tail 22mm (0.9-in.) wider than that of the previous model. The redesigned wing spoiler has been aligned to the wider profile, and slopes downward slightly at each end to nestle the rear fender’s contours. The lateral air inlets behind the doors have also been redrawn, and together with the new air ducts, afford a more efficient supply of cooling air to the intercoolers.
The 2007 911 Turbo goes on sale this summer in North America. U.S. pricing for the new model is $122,900. Complete information on all Porsche models can be found at www.press.porsche.com in the Press Kit section.
Porsche Cars North America, Inc. (PCNA), based in Atlanta, GA, and its subsidiary, Porsche Cars Canada, Ltd., are the exclusive importers of Porsche sports cars and Cayenne sport utility vehicles for the United States and Canada. A wholly owned, indirect subsidiary of Dr. Ing. h.c. F. Porsche AG, PCNA employs approximately 300 people who provide Porsche vehicles, parts, service, marketing and training for its 211 U.S. and Canadian dealers. They, in turn, provide Porsche owners with best-in-class service.
For more information, contact: Bob Carlson (770) 290-3676
