Is there an option to get rid of the ash tray and instead have a 12v DC power supply there with/without some storage area/bin ? I wanted to integrate my iPod's FM transmitter into the ash tray area and have a piece which plugs directly into the cigarette lighter 12v DC socket.
If the solution isin't as clean as having a proper cigarette lighter 12v dc socket (the round socket), I can crack open most of the transmitter and directly wire it and reassemble it below the plastic - leaving just the ipod connecting cable visable in that area.
I know how to get the middle plastic unit off but I don't know which wires are for what below there. Some snaps would help !
Sid
Hmm, that's pretty nice. What is the part number on that dual-power source socket ? Also, where and how did you mount them ? Looks like the male end of the dual power supply fits onto the female "phone power supply" cable from becker ? Am I right ?
Also, do I really need the becker phone power cable (p/n 5001.524-276) ? Can't I directly tap into the power wire that might already exist in the car ? Is there an installation guide online on how to install the becker phone power cable ? That way I can identify the existing power wires and directly use them instead of adding an intermediate 4 pin plug becker provides. I'm thinking of this since it appears that all the becker unit does is provide a 4 pins socket while all I really need are just wires (+ a 1-2 amp fuse in the middle from radio shack). Once I've identified the power wires, I stick in the dual power supply like the one you use. The nthe only problem is mounting those dual power supply sockets as elegantly as possible.
Do we know the current carrying capacity of the power lines I intend to tap into ? I wanted to put the appropriate fuses between the wires and the devices...
thanks !!
Sid
Edited by siddharth
You could hide all the cables under dashboard which you can pull down and hide cables.
1st, thanks for the pics ! A pic is worth a 1000 words ... true in this case ! :) So I'm assuming that you've not exposed the round female power socket in an accessible area ? You've connected your wires thru the regular car chargers and kept the whole bundle (female power socket + male car charger) in that space running only minimal wires in/out ?
1) What's the part number for the dual female power socket you mentioned in your 1st post ?
2) Any ideas on what the maximum current capacity is for the 12v supply ? I wanted to put in a fuse with around 75% of the max current capacity so I don't blow things deeper in the wiring ...
Edited by siddharth
