I have a re-occurring problem with my window washer tank - the hose somehow keeps working loose. When I refill the washer tank on my 2001 Boxster the water runs straight out again.
Does anyone have any pictures or description of how to access the washer tank and rectify a loose window washer hose to the window washer tank?
I looked this over in the bentley manual a few days ago, it shows that to remove it, or get access to it's underside, that you have to take off the driver's side wheel well liner, after you do that everything is right there
if you've got a set of jack stands you can probably get access to it in 30 minutes or so
