hi i have a problem i bought a used pcm II and try to install it in my 2000 boxster,but i belive the pcm II only have an audio output and this is thru the optical output,but my amplifier not have any optical imput,what can i do? need to change my amplifier? how is the amplifier that i need? and the part number of this amplifier? thanks for all
Bad news - your car does not have the optical bus (MOST system) or the MOST gateway system controller - nor will your DME (DME 5.2.2) send the proper signals (PCM2 gets some of it's data from the DME (7.8) and newer design instrument cluster). Those parts will only work in MY03 or newer car.
Bad news - your car does not have the optical bus (MOST system) or the MOST gateway system controller - nor will your DME (DME 5.2.2)send the proper signals (PCM2 gets some of it's data from the DME (7.8) and newer design instrument cluster). Those parts will only work in MY03 or newer car.
but i have the optical fiber cable,with this cable connected directly to a amplifier with optical fiber inputs,don not work?
